Executions for behaviour:
"1:R0=1 ; x=2 ; z=2"
ARM S+PPO188 "Wse DMBdWW Rfe PosRR DpAddrdR PosRW PosWW PosWR DpAddrdW" Cycle=Rfe PosRR DpAddrdR PosRW PosWW PosWR DpAddrdW Wse DMBdWW Relax= Safe=Rfe Wse PosWW PosWR PosRW PosRR DMBdWW DpAddrdW DpAddrdR Prefetch=0:x=F,1:x=W Orig=Wse DMBdWW Rfe PosRR DpAddrdR PosRW PosWW PosWR DpAddrdW { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | EOR R2,R1,R1 ; MOV R1, #1 | LDR R3, [R2,%z1] ; STR R1, [%y0] | MOV R4, #1 ; | STR R4, [%z1] ; | MOV R5, #2 ; | STR R5, [%z1] ; | LDR R6, [%z1] ; | EOR R7,R6,R6 ; | MOV R8, #1 ; | STR R8, [R7,%x1] ; Observed 1:R0=1; x=2; z=2;
