Test S+PPO176
Executions for behaviour: "1:R0=1 ; x=2 ; z=2"
ARM S+PPO176
"Wse DMBdWW Rfe PosRR DpDatadW PosWW PosWR DpAddrdW"
Cycle=Rfe PosRR DpDatadW PosWW PosWR DpAddrdW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWW PosWR PosRR DMBdWW DpAddrdW DpDatadW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpDatadW PosWW PosWR DpAddrdW
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0            | P1               ;
 MOV R0, #2    | LDR R0, [%y1]    ;
 STR R0, [%x0] | LDR R1, [%y1]    ;
 DMB           | EOR R2,R1,R1     ;
 MOV R1, #1    | ADD R2, R2, #1   ;
 STR R1, [%y0] | STR R2, [%z1]    ;
               | MOV R3, #2       ;
               | STR R3, [%z1]    ;
               | LDR R4, [%z1]    ;
               | EOR R5,R4,R4     ;
               | MOV R6, #1       ;
               | STR R6, [R5,%x1] ;
Observed
    1:R0=1; x=2; z=2;
