Test MP+PPO658
Executions for behaviour: "1:R0=1 ; 1:R3=1 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R3=2 ; x=2"
ARM MP+PPO658
"Fre DMBdWW Rfe PosRR DpDatadW PosWR"
Cycle=Rfe PosRR DpDatadW PosWR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRR DMBdWW DpDatadW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRR DpDatadW PosWR
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0            | P1             ;
 MOV R0, #2    | LDR R0, [%y1]  ;
 STR R0, [%x0] | LDR R1, [%y1]  ;
 DMB           | EOR R2,R1,R1   ;
 MOV R1, #1    | ADD R2, R2, #1 ;
 STR R1, [%y0] | STR R2, [%x1]  ;
               | LDR R3, [%x1]  ;
Observed
    1:R0=1; 1:R3=1; x=2;
and 1:R0=1; 1:R3=2; x=2;
