Test MP+PPO638
Executions for behaviour: "1:R0=1 ; 1:R5=1 ; x=2"
ARM MP+PPO638
"Fre DMBdWW Rfe PosRR DpCtrldW PosWR DpDatadW PosWR"
Cycle=Rfe PosRR DpCtrldW PosWR DpDatadW PosWR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRR DMBdWW DpDatadW DpCtrldW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRR DpCtrldW PosWR DpDatadW PosWR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0            | P1             ;
 MOV R0, #2    | LDR R0, [%y1]  ;
 STR R0, [%x0] | LDR R1, [%y1]  ;
 DMB           | CMP R1, R1     ;
 MOV R1, #1    | BNE LC00       ;
 STR R1, [%y0] | LC00:          ;
               | MOV R2, #1     ;
               | STR R2, [%z1]  ;
               | LDR R3, [%z1]  ;
               | EOR R4,R3,R3   ;
               | ADD R4, R4, #1 ;
               | STR R4, [%x1]  ;
               | LDR R5, [%x1]  ;
Observed
    1:R0=1; 1:R5=1; x=2;
