Test MP+PPO628
Executions for behaviour: "1:R0=1 ; 1:R6=1 ; x=2 ; y=2"
ARM MP+PPO628
"Fre DMBdWW Rfe PosRW PosWR DpDatadW PosWR DpDatadW PosWR"
Cycle=Rfe PosRW PosWR DpDatadW PosWR DpDatadW PosWR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRW DMBdWW DpDatadW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRW PosWR DpDatadW PosWR DpDatadW PosWR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0            | P1             ;
 MOV R0, #2    | LDR R0, [%y1]  ;
 STR R0, [%x0] | MOV R1, #2     ;
 DMB           | STR R1, [%y1]  ;
 MOV R1, #1    | LDR R2, [%y1]  ;
 STR R1, [%y0] | EOR R3,R2,R2   ;
               | ADD R3, R3, #1 ;
               | STR R3, [%z1]  ;
               | LDR R4, [%z1]  ;
               | EOR R5,R4,R4   ;
               | ADD R5, R5, #1 ;
               | STR R5, [%x1]  ;
               | LDR R6, [%x1]  ;
Observed
    1:R0=1; 1:R6=1; x=2; y=2;
