Executions for behaviour:
"1:R0=1 ; 1:R7=1 ; x=2"
ARM MP+PPO624 "Fre DMBdWW Rfe PosRR DpAddrdR DpDatadW PosWR DpDatadW PosWR" Cycle=Rfe PosRR DpAddrdR DpDatadW PosWR DpDatadW PosWR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRR DMBdWW DpAddrdR DpDatadW Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR DpAddrdR DpDatadW PosWR DpDatadW PosWR { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | EOR R2,R1,R1 ; MOV R1, #1 | LDR R3, [R2,%z1] ; STR R1, [%y0] | EOR R4,R3,R3 ; | ADD R4, R4, #1 ; | STR R4, [%a1] ; | LDR R5, [%a1] ; | EOR R6,R5,R5 ; | ADD R6, R6, #1 ; | STR R6, [%x1] ; | LDR R7, [%x1] ; Observed 1:R0=1; 1:R7=1; x=2;
