Executions for behaviour:
"1:R0=1 ; 1:R8=1 ; x=2"
ARM MP+PPO576 "Fre DMBdWW Rfe PosRR DpAddrdW PosWR PosRR DpAddrdW PosWR" Cycle=Rfe PosRR DpAddrdW PosWR PosRR DpAddrdW PosWR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRR DMBdWW DpAddrdW Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR DpAddrdW PosWR PosRR DpAddrdW PosWR { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | EOR R2,R1,R1 ; MOV R1, #1 | MOV R3, #1 ; STR R1, [%y0] | STR R3, [R2,%z1] ; | LDR R4, [%z1] ; | LDR R5, [%z1] ; | EOR R6,R5,R5 ; | MOV R7, #1 ; | STR R7, [R6,%x1] ; | LDR R8, [%x1] ; Observed 1:R0=1; 1:R8=1; x=2;
