Executions for behaviour:
"1:R0=1 ; 1:R8=1 ; x=2 ; y=2"
"1:R0=1 ; 1:R8=2 ; x=2 ; y=2"
ARM MP+PPO513 "Fre DMBdWW Rfe PosRR PosRW PosWR DpAddrdR DpAddrdW PosWR" Cycle=Rfe PosRR PosRW PosWR DpAddrdR DpAddrdW PosWR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpAddrdW DpAddrdR Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR PosRW PosWR DpAddrdR DpAddrdW PosWR { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | MOV R2, #2 ; MOV R1, #1 | STR R2, [%y1] ; STR R1, [%y0] | LDR R3, [%y1] ; | EOR R4,R3,R3 ; | LDR R5, [R4,%z1] ; | EOR R6,R5,R5 ; | MOV R7, #1 ; | STR R7, [R6,%x1] ; | LDR R8, [%x1] ; Observed 1:R0=1; 1:R8=1; x=2; y=2; and 1:R0=1; 1:R8=2; x=2; y=2;
