Executions for behaviour:
"1:R0=1 ; 1:R7=0 ; z=2"
ARM MP+PPO414 "Fre DMBdWW Rfe PosRR DpAddrdW PosWR PosRW PosWR DpCtrlIsbdR" Cycle=Rfe PosRR DpAddrdW PosWR PosRW PosWR DpCtrlIsbdR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpAddrdW DpCtrlIsbdR Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR DpAddrdW PosWR PosRW PosWR DpCtrlIsbdR { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #1 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | EOR R2,R1,R1 ; MOV R1, #1 | MOV R3, #1 ; STR R1, [%y0] | STR R3, [R2,%z1] ; | LDR R4, [%z1] ; | MOV R5, #2 ; | STR R5, [%z1] ; | LDR R6, [%z1] ; | CMP R6, R6 ; | BNE LC00 ; | LC00: ; | ISB ; | LDR R7, [%x1] ; Observed 1:R0=1; 1:R7=0; z=2;
