Executions for behaviour:
"1:R0=1 ; 1:R6=0"
ARM MP+PPO410 "Fre DMBdWW Rfe PosRR DpAddrdR PosRW PosWR DpCtrlIsbdR" Cycle=Rfe PosRR DpAddrdR PosRW PosWR DpCtrlIsbdR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpAddrdR DpCtrlIsbdR Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR DpAddrdR PosRW PosWR DpCtrlIsbdR { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #1 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | EOR R2,R1,R1 ; MOV R1, #1 | LDR R3, [R2,%z1] ; STR R1, [%y0] | MOV R4, #1 ; | STR R4, [%z1] ; | LDR R5, [%z1] ; | CMP R5, R5 ; | BNE LC00 ; | LC00: ; | ISB ; | LDR R6, [%x1] ; Observed 1:R0=1; 1:R6=0;
