Test MP+PPO366
Executions for behaviour: "1:R0=1 ; 1:R6=0 ; y=2"
ARM MP+PPO366
"Fre DMBdWW Rfe PosRR PosRW PosWR DpCtrldW PosWR DpCtrlIsbdR"
Cycle=Rfe PosRR PosRW PosWR DpCtrldW PosWR DpCtrlIsbdR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpCtrldW DpCtrlIsbdR
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRR PosRW PosWR DpCtrldW PosWR DpCtrlIsbdR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0            | P1            ;
 MOV R0, #1    | LDR R0, [%y1] ;
 STR R0, [%x0] | LDR R1, [%y1] ;
 DMB           | MOV R2, #2    ;
 MOV R1, #1    | STR R2, [%y1] ;
 STR R1, [%y0] | LDR R3, [%y1] ;
               | CMP R3, R3    ;
               | BNE LC00      ;
               | LC00:         ;
               | MOV R4, #1    ;
               | STR R4, [%z1] ;
               | LDR R5, [%z1] ;
               | CMP R5, R5    ;
               | BNE LC01      ;
               | LC01:         ;
               | ISB           ;
               | LDR R6, [%x1] ;
Observed
    1:R0=1; 1:R6=0; y=2;
