Test MP+PPO289
Executions for behaviour: "1:R0=1 ; 1:R8=0 ; y=2"
ARM MP+PPO289
"Fre DMBdWW Rfe PosRW PosWR DpAddrdR DpAddrdW PosWR DpCtrlIsbdR"
Cycle=Rfe PosRW PosWR DpAddrdR DpAddrdW PosWR DpCtrlIsbdR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRW DMBdWW DpAddrdW DpAddrdR DpCtrlIsbdR
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRW PosWR DpAddrdR DpAddrdW PosWR DpCtrlIsbdR
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
 P0            | P1               ;
 MOV R0, #1    | LDR R0, [%y1]    ;
 STR R0, [%x0] | MOV R1, #2       ;
 DMB           | STR R1, [%y1]    ;
 MOV R1, #1    | LDR R2, [%y1]    ;
 STR R1, [%y0] | EOR R3,R2,R2     ;
               | LDR R4, [R3,%z1] ;
               | EOR R5,R4,R4     ;
               | MOV R6, #1       ;
               | STR R6, [R5,%a1] ;
               | LDR R7, [%a1]    ;
               | CMP R7, R7       ;
               | BNE LC00         ;
               | LC00:            ;
               | ISB              ;
               | LDR R8, [%x1]    ;
Observed
    1:R0=1; 1:R8=0; y=2;
