Executions for behaviour:
"1:R0=1 ; 1:R6=0"
ARM MP+PPO232 "Fre DMBdWW Rfe PosRR DpDatadW PosWR DpAddrdR DpCtrlIsbdR" Cycle=Rfe PosRR DpDatadW PosWR DpAddrdR DpCtrlIsbdR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRR DMBdWW DpAddrdR DpDatadW DpCtrlIsbdR Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR DpDatadW PosWR DpAddrdR DpCtrlIsbdR { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; MOV R0, #1 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | EOR R2,R1,R1 ; MOV R1, #1 | ADD R2, R2, #1 ; STR R1, [%y0] | STR R2, [%z1] ; | LDR R3, [%z1] ; | EOR R4,R3,R3 ; | LDR R5, [R4,%a1] ; | CMP R5, R5 ; | BNE LC00 ; | LC00: ; | ISB ; | LDR R6, [%x1] ; Observed 1:R0=1; 1:R6=0;
