Executions for behaviour:
"1:R0=1 ; 1:R1=0 ; 3:R0=1 ; 3:R2=4 ; x=3"
"1:R0=1 ; 1:R1=0 ; 3:R0=0 ; 3:R2=2 ; x=4"
"1:R0=1 ; 1:R1=2 ; 3:R0=0 ; 3:R2=2 ; x=4"
"1:R0=1 ; 1:R1=0 ; 3:R0=3 ; 3:R2=2 ; x=4"
"1:R0=1 ; 1:R1=2 ; 3:R0=3 ; 3:R2=2 ; x=4"
"1:R0=1 ; 1:R1=0 ; 3:R0=0 ; 3:R2=3 ; x=4"
"1:R0=1 ; 1:R1=2 ; 3:R0=0 ; 3:R2=3 ; x=4"
"1:R0=1 ; 1:R1=0 ; 3:R0=0 ; 3:R2=4 ; x=4"
"1:R0=1 ; 1:R1=2 ; 3:R0=0 ; 3:R2=4 ; x=4"
"1:R0=1 ; 1:R1=0 ; 3:R0=3 ; 3:R2=4 ; x=4"
"1:R0=1 ; 1:R1=2 ; 3:R0=3 ; 3:R2=4 ; x=4"
ARM MOREDETOUR0831 "DMBdWW Rfe DetourR DpAddrdW DetourWW Wse" Cycle=Rfe DetourR DpAddrdW DetourWW Wse DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe DetourR DpAddrdW DetourWW Wse { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; %x3=x; } P0 | P1 | P2 | P3 ; MOV R0,#4 | LDR R0,[%y1] | MOV R0,#2 | LDR R0,[%x3] ; STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] | MOV R1,#2 ; DMB | EOR R2,R1,R1 | | STR R1,[%x3] ; MOV R1,#1 | MOV R3,#1 | | DMB ; STR R1,[%y0] | STR R3,[R2,%x1] | | LDR R2,[%x3] ; | MOV R4,#3 | | ; | STR R4,[%x1] | | ; Observed 1:R0=1; 1:R1=0; 3:R0=1; 3:R2=4; x=3; and 1:R0=1; 1:R1=0; 3:R0=0; 3:R2=2; x=4; and 1:R0=1; 1:R1=2; 3:R0=0; 3:R2=2; x=4; and 1:R0=1; 1:R1=0; 3:R0=3; 3:R2=2; x=4; and 1:R0=1; 1:R1=2; 3:R0=3; 3:R2=2; x=4; and 1:R0=1; 1:R1=0; 3:R0=0; 3:R2=3; x=4; and 1:R0=1; 1:R1=2; 3:R0=0; 3:R2=3; x=4; and 1:R0=1; 1:R1=0; 3:R0=0; 3:R2=4; x=4; and 1:R0=1; 1:R1=2; 3:R0=0; 3:R2=4; x=4; and 1:R0=1; 1:R1=0; 3:R0=3; 3:R2=4; x=4; and 1:R0=1; 1:R1=2; 3:R0=3; 3:R2=4; x=4;
