Executions for behaviour:
"0:R0=3 ; 1:R0=1 ; 2:R0=0 ; x=2"
"0:R0=1 ; 1:R0=1 ; 2:R0=1 ; x=2"
"0:R0=2 ; 1:R0=1 ; 2:R0=1 ; x=2"
"0:R0=1 ; 1:R0=1 ; 2:R0=3 ; x=2"
"0:R0=2 ; 1:R0=1 ; 2:R0=3 ; x=2"
"0:R0=3 ; 1:R0=1 ; 2:R0=3 ; x=2"
"0:R0=1 ; 1:R0=1 ; 2:R0=0 ; x=3"
"0:R0=3 ; 1:R0=1 ; 2:R0=0 ; x=3"
"0:R0=1 ; 1:R0=1 ; 2:R0=1 ; x=3"
"0:R0=2 ; 1:R0=1 ; 2:R0=1 ; x=3"
"0:R0=3 ; 1:R0=1 ; 2:R0=1 ; x=3"
ARM MOREDETOUR0248 "DpDatadW Rfe PosRR DpCtrldW DetourWW Rfe" Cycle=Rfe PosRR DpCtrldW DetourWW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe PosRR DpCtrldW DetourWW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; LDR R0,[%x0] | LDR R0,[%y1] | LDR R0,[%x2] ; EOR R1,R0,R0 | LDR R1,[%y1] | MOV R1,#2 ; ADD R1,R1,#1 | CMP R1,R1 | STR R1,[%x2] ; STR R1,[%y0] | BNE LC00 | ; | LC00: | ; | MOV R2,#1 | ; | STR R2,[%x1] | ; | MOV R3,#3 | ; | STR R3,[%x1] | ; Observed 0:R0=3; 1:R0=1; 2:R0=0; x=2; and 0:R0=1; 1:R0=1; 2:R0=1; x=2; and 0:R0=2; 1:R0=1; 2:R0=1; x=2; and 0:R0=1; 1:R0=1; 2:R0=3; x=2; and 0:R0=2; 1:R0=1; 2:R0=3; x=2; and 0:R0=3; 1:R0=1; 2:R0=3; x=2; and 0:R0=1; 1:R0=1; 2:R0=0; x=3; and 0:R0=3; 1:R0=1; 2:R0=0; x=3; and 0:R0=1; 1:R0=1; 2:R0=1; x=3; and 0:R0=2; 1:R0=1; 2:R0=1; x=3; and 0:R0=3; 1:R0=1; 2:R0=1; x=3;
