Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; x=2"
"0:R0=3 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; x=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=2 ; 3:R0=0 ; x=2"
"0:R0=3 ; 1:R0=1 ; 1:R1=2 ; 3:R0=0 ; x=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=1 ; x=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=3 ; x=2"
"0:R0=2 ; 1:R0=1 ; 1:R1=0 ; 3:R0=3 ; x=2"
"0:R0=3 ; 1:R0=1 ; 1:R1=0 ; 3:R0=3 ; x=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=2 ; 3:R0=3 ; x=2"
"0:R0=2 ; 1:R0=1 ; 1:R1=2 ; 3:R0=3 ; x=2"
"0:R0=3 ; 1:R0=1 ; 1:R1=2 ; 3:R0=3 ; x=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; x=3"
"0:R0=3 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; x=3"
"0:R0=1 ; 1:R0=1 ; 1:R1=2 ; 3:R0=0 ; x=3"
"0:R0=3 ; 1:R0=1 ; 1:R1=2 ; 3:R0=0 ; x=3"
"0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=1 ; x=3"
"0:R0=3 ; 1:R0=1 ; 1:R1=0 ; 3:R0=1 ; x=3"
"0:R0=1 ; 1:R0=1 ; 1:R1=2 ; 3:R0=1 ; x=3"
ARM MOREDETOUR0244 "DpDatadW Rfe DetourR DpDatadW DetourWW Rfe" Cycle=Rfe DetourR DpDatadW DetourWW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DetourR DpDatadW DetourWW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; %x3=x; } P0 | P1 | P2 | P3 ; LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2 | LDR R0,[%x3] ; EOR R1,R0,R0 | LDR R1,[%y1] | STR R0,[%y2] | MOV R1,#2 ; ADD R1,R1,#1 | EOR R2,R1,R1 | | STR R1,[%x3] ; STR R1,[%y0] | ADD R2,R2,#1 | | ; | STR R2,[%x1] | | ; | MOV R3,#3 | | ; | STR R3,[%x1] | | ; Observed 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=0; x=2; and 0:R0=3; 1:R0=1; 1:R1=0; 3:R0=0; x=2; and 0:R0=1; 1:R0=1; 1:R1=2; 3:R0=0; x=2; and 0:R0=3; 1:R0=1; 1:R1=2; 3:R0=0; x=2; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=1; x=2; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=3; x=2; and 0:R0=2; 1:R0=1; 1:R1=0; 3:R0=3; x=2; and 0:R0=3; 1:R0=1; 1:R1=0; 3:R0=3; x=2; and 0:R0=1; 1:R0=1; 1:R1=2; 3:R0=3; x=2; and 0:R0=2; 1:R0=1; 1:R1=2; 3:R0=3; x=2; and 0:R0=3; 1:R0=1; 1:R1=2; 3:R0=3; x=2; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=0; x=3; and 0:R0=3; 1:R0=1; 1:R1=0; 3:R0=0; x=3; and 0:R0=1; 1:R0=1; 1:R1=2; 3:R0=0; x=3; and 0:R0=3; 1:R0=1; 1:R1=2; 3:R0=0; x=3; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=1; x=3; and 0:R0=3; 1:R0=1; 1:R1=0; 3:R0=1; x=3; and 0:R0=1; 1:R0=1; 1:R1=2; 3:R0=1; x=3;
