Test MOREDETOUR0236
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 2:R0=0 ; x=2"
Executions for behaviour: "0:R0=3 ; 1:R0=1 ; 2:R0=0 ; x=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 2:R0=1 ; x=2"
Executions for behaviour: "0:R0=2 ; 1:R0=1 ; 2:R0=1 ; x=2"
Executions for behaviour: "0:R0=2 ; 1:R0=1 ; 2:R0=3 ; x=2"
Executions for behaviour: "0:R0=3 ; 1:R0=1 ; 2:R0=3 ; x=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 2:R0=0 ; x=3"
Executions for behaviour: "0:R0=3 ; 1:R0=1 ; 2:R0=0 ; x=3"
Executions for behaviour: "0:R0=2 ; 1:R0=1 ; 2:R0=1 ; x=3"
Executions for behaviour: "0:R0=3 ; 1:R0=1 ; 2:R0=1 ; x=3"
ARM MOREDETOUR0236
"DpDatadW Rfe PosRR DpAddrdW DetourWW Rfe"
Cycle=Rfe PosRR DpAddrdW DetourWW Rfe DpDatadW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe PosRR DpAddrdW DetourWW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
%x2=x;
 P0           | P1              | P2           ;
 LDR R0,[%x0] | LDR R0,[%y1]    | LDR R0,[%x2] ;
 EOR R1,R0,R0 | LDR R1,[%y1]    | MOV R1,#2    ;
 ADD R1,R1,#1 | EOR R2,R1,R1    | STR R1,[%x2] ;
 STR R1,[%y0] | MOV R3,#1       |              ;
              | STR R3,[R2,%x1] |              ;
              | MOV R4,#3       |              ;
              | STR R4,[%x1]    |              ;
Observed
    0:R0=1; 1:R0=1; 2:R0=0; x=2;
and 0:R0=3; 1:R0=1; 2:R0=0; x=2;
and 0:R0=1; 1:R0=1; 2:R0=1; x=2;
and 0:R0=2; 1:R0=1; 2:R0=1; x=2;
and 0:R0=2; 1:R0=1; 2:R0=3; x=2;
and 0:R0=3; 1:R0=1; 2:R0=3; x=2;
and 0:R0=1; 1:R0=1; 2:R0=0; x=3;
and 0:R0=3; 1:R0=1; 2:R0=0; x=3;
and 0:R0=2; 1:R0=1; 2:R0=1; x=3;
and 0:R0=3; 1:R0=1; 2:R0=1; x=3;
