Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB0102 "DpDatadW Rfe PosRR DpAddrdW PodWW Rfe" Cycle=Rfe PosRR DpAddrdW PodWW Rfe DpDatadW Relax=[Rfe,DpDatadW,Rfe] Safe=PosRR PodWW DpAddrdW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe PosRR DpAddrdW PodWW Rfe { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; EOR R1,R0,R0 | LDR R1,[%y1] ; ADD R1,R1,#1 | EOR R2,R1,R1 ; STR R1,[%y0] | MOV R3,#1 ; | STR R3,[R2,%z1] ; | MOV R4,#1 ; | STR R4,[%x1] ; Observed 0:R0=1; 1:R0=1;
