Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 1:R4=2 ; z=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=1 ; 1:R4=2 ; z=2"
ARM LB+data+pos-data-wsi-rfi-addr-po
"DpDatadW Rfe PosRR DpDatadW Wsi Rfi DpAddrdR PodRW Rfe"
Cycle=Rfi DpAddrdR PodRW Rfe DpDatadW Rfe PosRR DpDatadW Wsi
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe PosRR DpDatadW Wsi Rfi DpAddrdR PodRW Rfe
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
P0 | P1 ;
LDR R0,[%x0] | LDR R0,[%y1] ;
EOR R1,R0,R0 | LDR R1,[%y1] ;
ADD R1,R1,#1 | EOR R2,R1,R1 ;
STR R1,[%y0] | ADD R2,R2,#1 ;
| STR R2,[%z1] ;
| MOV R3,#2 ;
| STR R3,[%z1] ;
| LDR R4,[%z1] ;
| EOR R5,R4,R4 ;
| LDR R6,[R5,%a1] ;
| MOV R7,#1 ;
| STR R7,[%x1] ;
Observed
0:R0=1; 1:R0=1; 1:R1=0; 1:R4=2; z=2;
and 0:R0=1; 1:R0=1; 1:R1=1; 1:R4=2; z=2;
