Test LB+data+fri-wsi-rfi-data
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=3 ; y=3"
ARM LB+data+fri-wsi-rfi-data
"DpDatadW Rfe Fri Wsi Rfi DpDatadW Rfe"
Cycle=Rfi DpDatadW Rfe DpDatadW Rfe Fri Wsi
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe Fri Wsi Rfi DpDatadW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1           ;
 LDR R0,[%x0] | LDR R0,[%y1] ;
 EOR R1,R0,R0 | MOV R1,#2    ;
 ADD R1,R1,#1 | STR R1,[%y1] ;
 STR R1,[%y0] | MOV R2,#3    ;
              | STR R2,[%y1] ;
              | LDR R3,[%y1] ;
              | EOR R4,R3,R3 ;
              | ADD R4,R4,#1 ;
              | STR R4,[%x1] ;
Observed
    0:R0=1; 1:R0=1; 1:R3=3; y=3;
