Test LB+data+fri-wsi-rfi-addr
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=3 ; y=3"
ARM LB+data+fri-wsi-rfi-addr
"DpDatadW Rfe Fri Wsi Rfi DpAddrdW Rfe"
Cycle=Rfi DpAddrdW Rfe DpDatadW Rfe Fri Wsi
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe Fri Wsi Rfi DpAddrdW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1              ;
 LDR R0,[%x0] | LDR R0,[%y1]    ;
 EOR R1,R0,R0 | MOV R1,#2       ;
 ADD R1,R1,#1 | STR R1,[%y1]    ;
 STR R1,[%y0] | MOV R2,#3       ;
              | STR R2,[%y1]    ;
              | LDR R3,[%y1]    ;
              | EOR R4,R3,R3    ;
              | MOV R5,#1       ;
              | STR R5,[R4,%x1] ;
Observed
    0:R0=1; 1:R0=1; 1:R3=3; y=3;
