Test LB+data+detrw-wsi-rfi-ctrl
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=4 ; 2:R0=0 ; 2:R2=2 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=4 ; 2:R0=1 ; 2:R2=2 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=4 ; 2:R0=4 ; 2:R2=2 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=4 ; 2:R0=0 ; 2:R2=1 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=4 ; 2:R0=0 ; 2:R2=2 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=4 ; 2:R0=0 ; 2:R2=4 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=4 ; 2:R0=1 ; 2:R2=4 ; y=4"
ARM LB+data+detrw-wsi-rfi-ctrl
"DpDatadW Rfe DetourRW Wsi Rfi DpCtrldW Rfe"
Cycle=Rfi DpCtrldW Rfe DpDatadW Rfe DetourRW Wsi
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe DetourRW Wsi Rfi DpCtrldW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
 P0           | P1           | P2           ;
 LDR R0,[%x0] | LDR R0,[%y1] | LDR R0,[%y2] ;
 EOR R1,R0,R0 | MOV R1,#3    | MOV R1,#2    ;
 ADD R1,R1,#1 | STR R1,[%y1] | STR R1,[%y2] ;
 STR R1,[%y0] | MOV R2,#4    | DMB          ;
              | STR R2,[%y1] | LDR R2,[%y2] ;
              | LDR R3,[%y1] |              ;
              | CMP R3,R3    |              ;
              | BNE LC00     |              ;
              | LC00:        |              ;
              | MOV R4,#1    |              ;
              | STR R4,[%x1] |              ;
Observed
    0:R0=1; 1:R0=1; 1:R3=4; 2:R0=0; 2:R2=2; y=2;
and 0:R0=1; 1:R0=1; 1:R3=4; 2:R0=1; 2:R2=2; y=2;
and 0:R0=1; 1:R0=1; 1:R3=4; 2:R0=4; 2:R2=2; y=2;
and 0:R0=1; 1:R0=1; 1:R3=4; 2:R0=0; 2:R2=1; y=4;
and 0:R0=1; 1:R0=1; 1:R3=4; 2:R0=0; 2:R2=2; y=4;
and 0:R0=1; 1:R0=1; 1:R3=4; 2:R0=0; 2:R2=4; y=4;
and 0:R0=1; 1:R0=1; 1:R3=4; 2:R0=1; 2:R2=4; y=4;
