Test LB+data+detrw-detw-data
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=0 ; 2:R2=2 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=1 ; 2:R2=2 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=3 ; 2:R2=2 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=4 ; 2:R2=2 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=0 ; 2:R2=1 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=0 ; 2:R2=2 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=1 ; 2:R2=2 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=4 ; 2:R2=2 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=0 ; 2:R2=3 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=1 ; 2:R2=3 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=4 ; 2:R2=3 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=0 ; 2:R2=2 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=1 ; 2:R2=2 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=3 ; 2:R2=2 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=0 ; 2:R2=3 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=1 ; 2:R2=3 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=0 ; 2:R2=4 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=1 ; 2:R2=4 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=3 ; 2:R0=3 ; 2:R2=4 ; y=4"
ARM LB+data+detrw-detw-data
"DpDatadW Rfe DetourRW DetourW DpDatadW Rfe"
Cycle=Rfe DetourRW DetourW DpDatadW Rfe DpDatadW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe DetourRW DetourW DpDatadW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
%y3=y;
 P0           | P1           | P2           | P3           ;
 LDR R0,[%x0] | LDR R0,[%y1] | LDR R0,[%y2] | MOV R0,#4    ;
 EOR R1,R0,R0 | MOV R1,#3    | MOV R1,#2    | STR R0,[%y3] ;
 ADD R1,R1,#1 | STR R1,[%y1] | STR R1,[%y2] |              ;
 STR R1,[%y0] | LDR R2,[%y1] | DMB          |              ;
              | EOR R3,R2,R2 | LDR R2,[%y2] |              ;
              | ADD R3,R3,#1 |              |              ;
              | STR R3,[%x1] |              |              ;
Observed
    0:R0=1; 1:R0=1; 1:R2=3; 2:R0=0; 2:R2=2; y=2;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=1; 2:R2=2; y=2;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=3; 2:R2=2; y=2;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=4; 2:R2=2; y=2;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=0; 2:R2=1; y=3;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=0; 2:R2=2; y=3;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=1; 2:R2=2; y=3;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=4; 2:R2=2; y=3;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=0; 2:R2=3; y=3;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=1; 2:R2=3; y=3;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=4; 2:R2=3; y=3;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=0; 2:R2=2; y=4;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=1; 2:R2=2; y=4;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=3; 2:R2=2; y=4;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=0; 2:R2=3; y=4;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=1; 2:R2=3; y=4;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=0; 2:R2=4; y=4;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=1; 2:R2=4; y=4;
and 0:R0=1; 1:R0=1; 1:R2=3; 2:R0=3; 2:R2=4; y=4;
