Test LB+data+data-wsi-rfi-addr-pos-po
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=2 ; z=2"
ARM LB+data+data-wsi-rfi-addr-pos-po
"DpDatadW Rfe DpDatadW Wsi Rfi DpAddrdR PosRR PodRW Rfe"
Cycle=Rfi DpAddrdR PosRR PodRW Rfe DpDatadW Rfe DpDatadW Wsi
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe DpDatadW Wsi Rfi DpAddrdR PosRR PodRW Rfe
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
 P0           | P1              ;
 LDR R0,[%x0] | LDR R0,[%y1]    ;
 EOR R1,R0,R0 | EOR R1,R0,R0    ;
 ADD R1,R1,#1 | ADD R1,R1,#1    ;
 STR R1,[%y0] | STR R1,[%z1]    ;
              | MOV R2,#2       ;
              | STR R2,[%z1]    ;
              | LDR R3,[%z1]    ;
              | EOR R4,R3,R3    ;
              | LDR R5,[R4,%a1] ;
              | LDR R6,[%a1]    ;
              | MOV R7,#1       ;
              | STR R7,[%x1]    ;
Observed
    0:R0=1; 1:R0=1; 1:R3=2; z=2;
