Test LB+PPO0373
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; x=2 ; y=2"
ARM LB+PPO0373
"PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpCtrldW PosWW"
Cycle=Rfe PosRR PosRW PosWR DpCtrldW PosWW PodWW Rfe DpDatadW
Relax=
Safe=Rfe PosWW PosWR PosRW PosRR Pod*W DpDatadW DpCtrldW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpCtrldW PosWW
%z0=z; %x0=x;
%x1=x; %y1=y; %z1=z;
 P0           | P1           ;
 LDR R0,[%z0] | LDR R0,[%x1] ;
 EOR R1,R0,R0 | LDR R1,[%x1] ;
 ADD R1,R1,#1 | MOV R2,#2    ;
 STR R1,[%x0] | STR R2,[%x1] ;
              | LDR R3,[%x1] ;
              | CMP R3,R3    ;
              | BNE LC00     ;
              | LC00:        ;
              | MOV R4,#1    ;
              | STR R4,[%y1] ;
              | MOV R5,#2    ;
              | STR R5,[%y1] ;
              | MOV R6,#1    ;
              | STR R6,[%z1] ;
Observed
    0:R0=1; 1:R0=1; x=2; y=2;
