Test LB+PPO0295
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; y=2"
ARM LB+PPO0295
"PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR PosRR DpCtrldW"
Cycle=Rfe DpDatadW Rfe DpDatadW PosWW PosWR PosRR DpCtrldW PodWW
Relax=
Safe=Rfe PosWW PosWR PosRR Pod*W DpDatadW DpCtrldW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR PosRR DpCtrldW
%a0=a; %x0=x;
%x1=x; %y1=y; %z1=z; %a1=a;
 P0           | P1           ;
 LDR R0,[%a0] | LDR R0,[%x1] ;
 EOR R1,R0,R0 | EOR R1,R0,R0 ;
 ADD R1,R1,#1 | ADD R1,R1,#1 ;
 STR R1,[%x0] | STR R1,[%y1] ;
              | MOV R2,#2    ;
              | STR R2,[%y1] ;
              | LDR R3,[%y1] ;
              | LDR R4,[%y1] ;
              | CMP R4,R4    ;
              | BNE LC00     ;
              | LC00:        ;
              | MOV R5,#1    ;
              | STR R5,[%z1] ;
              | MOV R6,#1    ;
              | STR R6,[%a1] ;
Observed
    0:R0=1; 1:R0=1; y=2;
