Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0235 "PodWW Rfe DpDatadW Rfe PosRR DpAddrdR DpCtrldW" Cycle=Rfe PosRR DpAddrdR DpCtrldW PodWW Rfe DpDatadW Relax= Safe=Rfe PosRR Pod*W DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpAddrdR DpCtrldW { %a0=a; %x0=x; %x1=x; %y1=y; %z1=z; %a1=a; } P0 | P1 ; LDR R0,[%a0] | LDR R0,[%x1] ; EOR R1,R0,R0 | LDR R1,[%x1] ; ADD R1,R1,#1 | EOR R2,R1,R1 ; STR R1,[%x0] | LDR R3,[R2,%y1] ; | CMP R3,R3 ; | BNE LC00 ; | LC00: ; | MOV R4,#1 ; | STR R4,[%z1] ; | MOV R5,#1 ; | STR R5,[%a1] ; Observed 0:R0=1; 1:R0=1;
