Test LB+PPO0110
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; y=2"
ARM LB+PPO0110
"PodWW Rfe DpDatadW Rfe PosRR DpDatadW PosWW PosWR DpAddrdW"
Cycle=Rfe PosRR DpDatadW PosWW PosWR DpAddrdW PodWW Rfe DpDatadW
Relax=
Safe=Rfe PosWW PosWR PosRR Pod*W DpAddrdW DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe PosRR DpDatadW PosWW PosWR DpAddrdW
%a0=a; %x0=x;
%x1=x; %y1=y; %z1=z; %a1=a;
 P0           | P1              ;
 LDR R0,[%a0] | LDR R0,[%x1]    ;
 EOR R1,R0,R0 | LDR R1,[%x1]    ;
 ADD R1,R1,#1 | EOR R2,R1,R1    ;
 STR R1,[%x0] | ADD R2,R2,#1    ;
              | STR R2,[%y1]    ;
              | MOV R3,#2       ;
              | STR R3,[%y1]    ;
              | LDR R4,[%y1]    ;
              | EOR R5,R4,R4    ;
              | MOV R6,#1       ;
              | STR R6,[R5,%z1] ;
              | MOV R7,#1       ;
              | STR R7,[%a1]    ;
Observed
    0:R0=1; 1:R0=1; y=2;
