Executions for behaviour:
"1:R1=1 ; x=2 ; y=1"
ARM DETOUR1255 "DMBdWW Wse Rfi PosRR DpDatadW Wse" Cycle=Rfi PosRR DpDatadW Wse DMBdWW Wse Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Ws Ws Orig=DMBdWW Wse Rfi PosRR DpDatadW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | MOV R0,#2 ; STR R0,[%x0] | STR R0,[%y1] ; DMB | LDR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | EOR R3,R2,R2 ; | ADD R3,R3,#1 ; | STR R3,[%x1] ; Observed 1:R1=1; x=2; y=1;
