Test DETOUR1128
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R2=0 ; x=2"
Executions for behaviour: "1:R0=0 ; 1:R1=1 ; 1:R2=0 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R2=0 ; x=2"
Executions for behaviour: "1:R0=0 ; 1:R1=1 ; 1:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R2=2 ; x=2"
Executions for behaviour: "1:R0=2 ; 1:R1=1 ; 1:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R1=2 ; 1:R2=2 ; x=2"
ARM DETOUR1128
"DMBdWW Rfe PosRR DetourR DpDatadW Wse"
Cycle=Rfe PosRR DetourR DpDatadW Wse DMBdWW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe PosRR DetourR DpDatadW Wse
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
 P0           | P1           | P2           ;
 MOV R0,#2    | LDR R0,[%y1] | MOV R0,#2    ;
 STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] ;
 DMB          | LDR R2,[%y1] |              ;
 MOV R1,#1    | EOR R3,R2,R2 |              ;
 STR R1,[%y0] | ADD R3,R3,#1 |              ;
              | STR R3,[%x1] |              ;
Observed
    1:R0=1; 1:R1=0; 1:R2=0; x=2;
and 1:R0=0; 1:R1=1; 1:R2=0; x=2;
and 1:R0=1; 1:R1=1; 1:R2=0; x=2;
and 1:R0=0; 1:R1=1; 1:R2=2; x=2;
and 1:R0=1; 1:R1=1; 1:R2=2; x=2;
and 1:R0=2; 1:R1=1; 1:R2=2; x=2;
and 1:R0=1; 1:R1=2; 1:R2=2; x=2;
