Test DETOUR1091
Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R3=3 ; x=2"
ARM DETOUR1091
"DMBdWW Rfe DetourR Fri Rfi DpAddrdW Wse"
Cycle=Rfi DpAddrdW Wse DMBdWW Rfe DetourR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe DetourR Fri Rfi DpAddrdW Wse
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
 P0           | P1              | P2           ;
 MOV R0,#2    | LDR R0,[%y1]    | MOV R0,#2    ;
 STR R0,[%x0] | LDR R1,[%y1]    | STR R0,[%y2] ;
 DMB          | MOV R2,#3       |              ;
 MOV R1,#1    | STR R2,[%y1]    |              ;
 STR R1,[%y0] | LDR R3,[%y1]    |              ;
              | EOR R4,R3,R3    |              ;
              | MOV R5,#1       |              ;
              | STR R5,[R4,%x1] |              ;
Observed
    1:R0=1; 1:R1=1; 1:R3=3; x=2;
