Executions for behaviour:
"1:R0=1 ; 1:R1=0 ; 1:R3=1 ; x=2"
"1:R0=1 ; 1:R1=2 ; 1:R3=1 ; x=2"
ARM DETOUR0699 "DMBdWW Rfe DetourR DpCtrldW PosWR Fre" Cycle=Rfe DetourR DpCtrldW PosWR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DetourR DpCtrldW PosWR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; MOV R0,#2 | LDR R0,[%y1] | MOV R0,#2 ; STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] ; DMB | CMP R1,R1 | ; MOV R1,#1 | BNE LC00 | ; STR R1,[%y0] | LC00: | ; | MOV R2,#1 | ; | STR R2,[%x1] | ; | LDR R3,[%x1] | ; Observed 1:R0=1; 1:R1=0; 1:R3=1; x=2; and 1:R0=1; 1:R1=2; 1:R3=1; x=2;
