Test DETOUR0680
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=0"
Executions for behaviour: "1:R0=0 ; 1:R1=1 ; 1:R3=0"
Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R3=0"
Executions for behaviour: "1:R0=2 ; 1:R1=1 ; 1:R3=0"
Executions for behaviour: "1:R0=1 ; 1:R1=2 ; 1:R3=0"
ARM DETOUR0680
"DMBdWW Rfe DetourR PosRR DpCtrlIsbdR Fre"
Cycle=Rfe DetourR PosRR DpCtrlIsbdR Fre DMBdWW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DetourR PosRR DpCtrlIsbdR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
 P0           | P1           | P2           ;
 MOV R0,#1    | LDR R0,[%y1] | MOV R0,#2    ;
 STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] ;
 DMB          | LDR R2,[%y1] |              ;
 MOV R1,#1    | CMP R2,R2    |              ;
 STR R1,[%y0] | BNE LC00     |              ;
              | LC00:        |              ;
              | ISB          |              ;
              | LDR R3,[%x1] |              ;
Observed
    1:R0=1; 1:R1=0; 1:R3=0;
and 1:R0=0; 1:R1=1; 1:R3=0;
and 1:R0=1; 1:R1=1; 1:R3=0;
and 1:R0=2; 1:R1=1; 1:R3=0;
and 1:R0=1; 1:R1=2; 1:R3=0;
