Executions for behaviour:
"0:R1=1 ; 2:R0=1 ; 2:R2=1"
"0:R1=1 ; 2:R0=1 ; 2:R2=3"
ARM DETOUR0401 "DetourW PosRR DpAddrdW Rfe DpDatadW Wse" Cycle=Rfe DpDatadW Wse DetourW PosRR DpAddrdW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DetourW PosRR DpAddrdW Rfe DpDatadW Wse { %x0=x; %y0=y; %x1=x; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV R0,#2 | MOV R0,#3 | LDR R0,[%y2] ; STR R0,[%x0] | STR R0,[%x1] | EOR R1,R0,R0 ; LDR R1,[%x0] | | ADD R1,R1,#1 ; LDR R2,[%x0] | | STR R1,[%x2] ; EOR R3,R2,R2 | | DMB ; MOV R4,#1 | | LDR R2,[%x2] ; STR R4,[R3,%y0] | | ; Observed 0:R1=1; 2:R0=1; 2:R2=1; and 0:R1=1; 2:R0=1; 2:R2=3;
