Executions for behaviour:
"0:R1=1 ; 1:R0=1 ; x=1"
ARM DETOUR0400 "Rfi PosRR DpAddrdW Rfe DpDatadW Wse" Cycle=Rfi PosRR DpAddrdW Rfe DpDatadW Wse Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=Rfi PosRR DpAddrdW Rfe DpDatadW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | EOR R1,R0,R0 ; LDR R1,[%x0] | ADD R1,R1,#1 ; LDR R2,[%x0] | STR R1,[%x1] ; EOR R3,R2,R2 | ; MOV R4,#1 | ; STR R4,[R3,%y0] | ; Observed 0:R1=1; 1:R0=1; x=1;
