Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; 1:R1=0"
"0:R0=1 ; 1:R0=1 ; 1:R1=2"
ARM DETOUR0275 "DpDatadW Rfe DetourR DpAddrdR DpCtrldW Rfe" Cycle=Rfe DetourR DpAddrdR DpCtrldW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DetourR DpAddrdR DpCtrldW Rfe { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; %y2=y; } P0 | P1 | P2 ; LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2 ; EOR R1,R0,R0 | LDR R1,[%y1] | STR R0,[%y2] ; ADD R1,R1,#1 | EOR R2,R1,R1 | ; STR R1,[%y0] | LDR R3,[R2,%z1] | ; | CMP R3,R3 | ; | BNE LC00 | ; | LC00: | ; | MOV R4,#1 | ; | STR R4,[%x1] | ; Observed 0:R0=1; 1:R0=1; 1:R1=0; and 0:R0=1; 1:R0=1; 1:R1=2;
