Executions for behaviour:
"0:R0=1 ; 1:R0=1"
"0:R0=2 ; 1:R0=1"
ARM DETOUR0165 "DpDatadW Rfe PosRR DpCtrldW Wsi Rfe" Cycle=Rfe PosRR DpCtrldW Wsi Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe PosRR DpCtrldW Wsi Rfe { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; EOR R1,R0,R0 | LDR R1,[%y1] ; ADD R1,R1,#1 | CMP R1,R1 ; STR R1,[%y0] | BNE LC00 ; | LC00: ; | MOV R2,#1 ; | STR R2,[%x1] ; | MOV R3,#2 ; | STR R3,[%x1] ; Observed 0:R0=1; 1:R0=1; and 0:R0=2; 1:R0=1;
