Executions for behaviour:
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=0 ; 3:R2=1 ; x=1"
Model | Tegra3 | Exynos4412 | Exynos5410 | APQ8064 | |
MOREDETOUR0812 | Forbid | Ok, 1/3.4G | No, 0/11G | No, 0/3.1G | No, 0/2.3G |
Allow unseen | Allow unseen | Allow unseen |
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=4 ; 3:R2=2 ; x=1"
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=4 ; 3:R2=3 ; x=1"
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=1 ; 3:R2=2 ; x=2"
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=3 ; 3:R2=2 ; x=2"
MOREDETOUR0812 | Forbid | Ok, 3/3.4G | No, 0/11G | No, 0/3.1G | No, 0/2.3G |
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=4 ; 3:R2=1 ; x=3"
MOREDETOUR0812 | Forbid | Ok, 5/3.4G | No, 0/11G | No, 0/3.1G | No, 0/2.3G |
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=0 ; 3:R2=2 ; x=3"
MOREDETOUR0812 | Forbid | Ok, 13/3.4G | No, 0/11G | No, 0/3.1G | No, 0/2.3G |
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=1 ; 3:R2=2 ; x=3"
MOREDETOUR0812 | Forbid | Ok, 25/3.4G | No, 0/11G | No, 0/3.1G | No, 0/2.3G |
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=4 ; 3:R2=2 ; x=3"
MOREDETOUR0812 | Forbid | Ok, 6/3.4G | No, 0/11G | No, 0/3.1G | No, 0/2.3G |
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 3:R0=1 ; 3:R2=3 ; x=3"
MOREDETOUR0812 | Forbid | Ok, 7/3.4G | No, 0/11G | No, 0/3.1G | No, 0/2.3G |
"1:R0=1 ; 1:R2=2 ; 1:R3=2 ; 3:R0=0 ; 3:R2=4 ; x=3"
MOREDETOUR0812 | Forbid | Ok, 2/3.4G | No, 0/11G | No, 0/3.1G | No, 0/2.3G |
"1:R0=1 ; 1:R2=2 ; 1:R3=2 ; 3:R0=1 ; 3:R2=4 ; x=3"
ARM MOREDETOUR0812 "DMBdWW Rfe DpAddrdR DetourR DetourRW Wse" Cycle=Rfe DpAddrdR DetourR DetourRW Wse DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe DpAddrdR DetourR DetourRW Wse { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; %x3=x; } P0 | P1 | P2 | P3 ; MOV R0,#4 | LDR R0,[%y1] | MOV R0,#1 | LDR R0,[%x3] ; STR R0,[%x0] | EOR R1,R0,R0 | STR R0,[%x2] | MOV R1,#2 ; DMB | LDR R2,[R1,%x1] | | STR R1,[%x3] ; MOV R1,#1 | LDR R3,[%x1] | | DMB ; STR R1,[%y0] | MOV R4,#3 | | LDR R2,[%x3] ; | STR R4,[%x1] | | ; Observed 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=0; 3:R2=1; x=1; and 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=4; 3:R2=2; x=1; and 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=4; 3:R2=3; x=1; and 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=1; 3:R2=2; x=2; and 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=3; 3:R2=2; x=2; and 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=4; 3:R2=1; x=3; and 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=0; 3:R2=2; x=3; and 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=1; 3:R2=2; x=3; and 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=4; 3:R2=2; x=3; and 1:R0=1; 1:R2=0; 1:R3=0; 3:R0=1; 3:R2=3; x=3; and 1:R0=1; 1:R2=2; 1:R3=2; 3:R0=0; 3:R2=4; x=3; and 1:R0=1; 1:R2=2; 1:R3=2; 3:R0=1; 3:R2=4; x=3;
