Executions for behaviour:
"1:R0=1 ; 1:R2=0 ; 1:R4=2 ; 2:R1=1 ; x=2"
Model | Tegra3 | Exynos4412 | Exynos5410 | APQ8064 | |
MOREDETOUR0503 | Forbid | Ok, 3/3.1G | No, 0/7.2G | No, 0/3.1G | No, 0/2.3G |
Allow unseen | Allow unseen | Allow unseen |
"1:R0=1 ; 1:R2=0 ; 1:R4=2 ; 2:R1=2 ; x=2"
MOREDETOUR0503 | Forbid | Ok, 2/3.1G | No, 0/7.2G | No, 0/3.1G | No, 0/2.3G |
"1:R0=1 ; 1:R2=1 ; 1:R4=2 ; 2:R1=4 ; x=2"
MOREDETOUR0503 | Forbid | Ok, 1/3.1G | No, 0/7.2G | No, 0/3.1G | No, 0/2.3G |
"1:R0=1 ; 1:R2=0 ; 1:R4=2 ; 2:R1=2 ; x=3"
ARM MOREDETOUR0503 "DMBdWW Rfe DpAddrdR DetourRW DetourW Fre" Cycle=Rfe DpAddrdR DetourRW DetourW Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpAddrdR DetourRW DetourW Fre { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; %x3=x; } P0 | P1 | P2 | P3 ; MOV R0,#4 | LDR R0,[%y1] | MOV R0,#1 | MOV R0,#3 ; STR R0,[%x0] | EOR R1,R0,R0 | STR R0,[%x2] | STR R0,[%x3] ; DMB | LDR R2,[R1,%x1] | DMB | ; MOV R1,#1 | MOV R3,#2 | LDR R1,[%x2] | ; STR R1,[%y0] | STR R3,[%x1] | | ; | LDR R4,[%x1] | | ; Observed 1:R0=1; 1:R2=0; 1:R4=2; 2:R1=1; x=2; and 1:R0=1; 1:R2=0; 1:R4=2; 2:R1=2; x=2; and 1:R0=1; 1:R2=1; 1:R4=2; 2:R1=4; x=2; and 1:R0=1; 1:R2=0; 1:R4=2; 2:R1=2; x=3;
