Model | APQ8060 | A5X | A6X | Exynos5250 | Tegra3 | Exynos4412 | Exynos5410 | APQ8064 | |
S+dmb+fri-rfi-ctrl | Forbid | No, 0/1.3G | No, 0/2.4G | No, 0/2.6G | No, 0/3.4G | No, 0/2.4G | No, 0/4.8G | No, 0/4.1G | Ok, 373k/4.6G |
Allow unseen | Allow unseen | Allow unseen | Allow unseen | Allow unseen | Allow unseen | Allow unseen |
Executions for behaviour:
"1:R0=1 ; 1:R2=2 ; x=2 ; y=2"
ARM S+dmb+fri-rfi-ctrl "DMBdWW Rfe Fri Rfi DpCtrldW Wse" Cycle=Rfi DpCtrldW Wse DMBdWW Rfe Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe Fri Rfi DpCtrldW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | MOV R1,#2 ; DMB | STR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | CMP R2,R2 ; | BNE LC00 ; | LC00: ; | MOV R3,#1 ; | STR R3,[%x1] ; Observed 1:R0=1; 1:R2=2; x=2; y=2;
