Test S+dmb+fri-rfi-addr
 ModelAPQ8060A5XA6XExynos5250Tegra3Exynos4412Exynos5410APQ8064
S+dmb+fri-rfi-addrForbidNo, 0/1.3GNo, 0/2.4GNo, 0/2.6GNo, 0/3.4GNo, 0/2.4GNo, 0/4.8GNo, 0/4.1GOk, 391k/4.6G
  Allow unseenAllow unseenAllow unseenAllow unseenAllow unseenAllow unseenAllow unseen
Executions for behaviour: "1:R0=1 ; 1:R2=2 ; x=2 ; y=2"
ARM S+dmb+fri-rfi-addr
"DMBdWW Rfe Fri Rfi DpAddrdW Wse"
Cycle=Rfi DpAddrdW Wse DMBdWW Rfe Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe Fri Rfi DpAddrdW Wse
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1              ;
 MOV R0,#2    | LDR R0,[%y1]    ;
 STR R0,[%x0] | MOV R1,#2       ;
 DMB          | STR R1,[%y1]    ;
 MOV R1,#1    | LDR R2,[%y1]    ;
 STR R1,[%y0] | EOR R3,R2,R2    ;
              | MOV R4,#1       ;
              | STR R4,[R3,%x1] ;
Observed
    1:R0=1; 1:R2=2; x=2; y=2;
